Hi,
Been trying to upload some files to an FTP, but have an issue.
There’s a file in /Volumes/CS/FULL.txt, but Read/Write Files from Disk node (read part) doesn’t return binary data at all?
It works fine if I move this file onto my /Users/user/Desktop/FULL.txt
Everything else works perfectly fine on the Volume (it’s a mounted smb).
Is there a reason why files on smb mount don’t return binary data?
(Works fine from Desktop path)
(same file, but sitting in a Volume - doesn’t return data).
Just in case, I’ve tried multiple file formats and sizes - no difference.
All other nodes seem to work fine, including binary write on the same folder in /volumes/CS/.
The FTP upload node requires binary data, so I was trying to read this file, then upload it to FTP, but get stuck a step behind this.
- n8n version: 1.65.2
- Database: SQLite (Default)
- Self-hosting with npm/npx, without Docker.
- Operating system: MacOS 10.14.6
