Mssql Node intermittent timeout - ERROR: Failed to connect to 10.31.10.11:1433 in 15000ms
I can normally connect and have success on queries on MSSQL but very frequently ( I mean if I run more than once a node or even on the first run) , i have intermittent error with timeout on the query mssql node. There is nothing that can help on the console output from n8n or even on MSSQL logs. All the other applications that connect on the server works fine. I
Details
Stack
ConnectionError: Failed to connect to 10.31.10.11:1433 in 15000ms
    at connectListener (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/node_modules/mssql/lib/tedious/connection-pool.js:78:17)
    at Connection.onConnect (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/node_modules/tedious/src/connection.ts:1763:9)
    at Object.onceWrapper (node:events:632:26)
    at Connection.emit (node:events:517:28)
    at Connection.emit (node:domain:489:12)
    at Connection.emit (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/node_modules/tedious/src/connection.ts:1906:18)
    at Connection.connectTimeout (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/node_modules/tedious/src/connection.ts:2092:10)
    at Timeout._onTimeout (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/node_modules/tedious/src/connection.ts:2044:12)
    at listOnTimeout (node:internal/timers:569:17)
    at processTimers (node:internal/timers:512:7)
titulos
Execute node
Parameters
Docs
Credential to connect with
Operation
Query
1
=SELECT * FROM TitulosAtraso WHERE codcli = {{ $json[“codcli”] }} ORDER BY vctori ASC
  • n8n version: Version 1.15.2
  • Database (default: SQLite): PostgreSQL
  • Operating system: MAC OSX Sonoma
Here, the output from docker console
Hey @Rodrigo_Carvalhaes,
It might be worth adding a retry under the node settings, The error itself looks like a standard timeout issue so there are not really a lot of things that can be done outside of just trying again.
