*Multi-employee* appointment booking with overlapping appointments - How to solve?
Multi-employee appointment booking with overlapping appointments// How to solve?
I am stuck and I need a booking system which handels
  1. Multiple employees (e.g. 3 staff members)
  2. The same time slot can be booked multiple times, up to the number of available employees
  3. Each employee has individual working hours
Currently, my n8n-based workflow only supports a single shared calendar, what works with VAPI (gives name, Start-/Endtime, number), calendar (checkavailability, create, update, cancel), airtable (create, search, update event). What is the best way to solve this problem? Really appreciate it, i find almost nothing in the internet abt it.
//in the meantime i got a tip from another user, he told me to keep an Airtable ‘Staff Pool’ with each employee’s working hours. “On a booking request, first query this table to find ‘which employee is free’ at that time. Then book the appointment to that specific employee’s calendar slot. The key is changing the question from ‘Is the slot free?’ to ‘Which resource is free?’.” So that´s my mission to first try that out. Anyways, I´m grateful for evaluaitons and help
Cheers to @maxT for the worki :partying_face:
Hi @Stefan_Sinz
Welcome to the community! :waving_hand:
Your current flow checks “Is this slot free?” (single-resource model), but with multiple staff you need to ask “Which staff member is available at this time?” instead.
Stop checking “if the time is free” and start checking “which staff member is free.”
Key rule: The same time slot can be booked up to the number of available staff members. Overbooking happens per staff member, not per slot.
How to implement
  1. Have one calendar per staff member
  2. Maintain a Staff table (Airtable/DB) with:
  • staff_id
  • calendar_id
  • working_hours
  1. On booking request:
  • List active staff members
  • Filter who works at that time
  1. For each staff member:
  • Google Calendar → Check FreeBusy
  • If no conflict → select that staff member
  1. Create the event on their calendar
  • If none are free → slot unavailable
Hi @Stefan_Sinz Welcome!
Just add an AI Agent for that, which will validate who is free and who is not and which resource is free at what time, with this you will be in control and there will no gap for errors like cross scheduling, just let the AI agent handle the booking so it can validate accordingly, i would recommend not using a shared calendar, it works but not recommended when dealing with multiple member assignment, hope this helps!
Hello @tamy.santos , thanks a lot for the warm welcoming and the helpful advise. I get it and it makes sense to do it that way. Currently I try to implement it as you suggested, but I struggle a bit as a non professional (yet :melting_face:). Is there a template or step-by-step guide that explains how to fetch calendar and Airtable/database data based on staff member availability, as you described? Would be amazing but otherwise I hope i get it done somehow.
Another question is, if I still need google calendar at all when I get all the Data I need from airtable. I think airtable would function well as a calender also.
Best wishes
Stefan
@Stefan_Sinz
See if these links can help you.
https://developers.google.com/workspace/calendar/api/v3/reference/freebusy?utm_source=chatgpt.com
