My Discord URL is not connecting
I am on my level 2 but my discord node is not working.
I shows “NodeOperationError: at ExecuteContext.parseDiscordError (/usr/local/lib/node_modules/n”
“errorMessage”: " [item 0]",
“errorDetails”: {},
“n8nDetails”: {
“nodeName”: “Discord”,
“nodeType”: “n8n-nodes-base.discord”,
“nodeVersion”: 2,
“operation”: “sendLegacy”,
“itemIndex”: 0,
“time”: “13/07/2025, 20:12:04”,
“n8nVersion”: “1.100.1 (Cloud)”,
“stackTrace”: [
"NodeOperationError: ",
" at ExecuteContext.parseDiscordError (
hey @Shan_Ali i do not understand error correctly but you can compare your workflow with this:
and double check your discord configuration in course 2 a different webhook is provided than course 1.
hope this helps.
