Building my very first test workflow, I based my workflow setting from @ giulioandreini in Parsing Json items, and practically nothing more is added to my workflow.
I set the workflow to accept multiple HTTP methods (GET and POST). Using production URL and web browser and GET, I get The URL of the Google search query for the term " " is:, which is expected.
Now, using the same production URL, using Postman and POST, I get “message”: “Error in workflow”.
Any idea why the difference?
n8n version 1.72.1
PostgreSQL 16
EXECUTIONS_PROCESS: default (no idea what it is yet)
<your workflow>
The workflow you pointed out to does not use the Webhook node. How do you try to use Postman in that case if nothing listens to incoming requests?
Could you share the actual workflow you have created as well as the error produced by the workflow (and in which node) when it responds to your HTTP request from Postman?
Hey @charleslcso , the problem is due to your Set node configuration which you set up to parse both GET and POST request in the same way. Hence POST produces the error while GET does not.
If you indeed want to support both HTTP methods separate the two outputs and treat them differently.
