My Loop does not work
Hello Hivemind,
I am trying to do a simple thing - a loop. The loop should start at a given date, do a subflow and iterate to the next day and do this until it reaches today.
It is working without the subflow, but it fails with the flow activated.
The date gets either stuck or gets set to seemigly random dates.
No error message.
  • n8n version: 1.44.1
  • Operating system: linux
Hi @Manuel
I need a little more context of what you are trying to do, but in general, when you’re trying to loop over items there is a node for that in particular:
It looks like you are trying to do some date formatting until your dataset has reached the current date? Can you share your workflow with some pinned data to see what which input you are working with? Also feel free to also share the subworkflow for better context.
Thanks! :blush:
