My n8n node is stuck in manual review for 2 months
Hi everyone,
my n8n ConvertHub node is stuck in manual review for 2 months already and haven’t got any response.
Is there anything we could do to move forward?
Thank you!
I would contact support if nothing has happened in 2 months, though I don’t know if the process is majorly different for nodes vs workflow template uploads.
thanks for the input… I did and the AI assistant recommended to open a discussion in the community forum.
I’ll search for their support email to contact them directly.
Yea, hopefully that’ll work
Mine as well got stuck for almost 3 months. Now what to do? IDK!
same here… I am not sure what to do as well, posting here, writing to support and I hope someone sees it
@venelinkochev @Mahbub_Rahman Has anything happened since?
Contact support. They’ll get back to reviewing. Mine is reviewing, but still pretty slow.
