My Onedrive Trigger is not Triggering
I’ve set up a OneDrive trigger that will trigger when a new file is uploaded into the designated folder. When I test the workflow, it works perfectly, but if I upload a new file to the designated folder, the trigger never triggers automatically. The workflow is activated. Any help would be appreciated.
No error messages
This is not a data problem, it’s just that the trigger never triggers.
  • running the cloud version 1.69.0
Hi @Steve_Cubberly
Thanks for posting here and welcome to the community! :raised_hands:
Are you uploading a file in that specific folder that you are watching in the trigger? Because from the workflow it looks like you’d be uploading to a sub-folder.
If that’s the case you would have to change the watch option:
