My [POST] webhook is not working
I have made [post] webhook and when i try it on postman it show error
“code”: 404,
“message”: “The requested webhook "GET test" is not registered.”,
“hint”: “The workflow must be active for a production URL to run successfully. You can activate the workflow using the toggle in the top-right of the editor. Note that unlike test URL calls, production URL calls aren’t shown on the canvas (only in the executions list)”
installen in Hetzner server (Docker CE ) using coolify latest version of n8n with default parameter
Activate the workflow in n8n and it will work
