I have an automation that works brilliantly except for a random event. The response from MySQL that has the “affected rows” and all that data gets passed as an item on the rarest of occasions. It breaks the nodes later in the automation. Here is a quick vid to show you what is happening.
Thanks as always,
Hi @coachmikemonte, I am sorry to hear you’re having trouble.
In a first step, could you identify which values your MySQL node was receiving from the previous node when it returned the unwanted result? Could you also share the exact query you were executing in the MySQL node?
@MutedJam do I copy and paste the flow here or is it better to post the errored run in the community? Still kind of new here, haha.
