I have a webhook trigger in my flow. I am simply trying to get it to work at this point (it works in Postman).
Here is my node:
I am working with Glide Low Code. It has a very simple interface and has an action called “Trigger Webhook”.
I have set it up so that when a button is pressed, my webhook triggers. All that Glide needs is a webhook URL to work which I have input. Here is an image of my Trigger Webhook action:
I have copied the test URL exactly from n8n.io into Glide.
Glide’s support told me it is receiving 404 errors and to double check the URL, but it works in Postman so I know that is not the case.
I would really appreciate any help, I am at a loss so far.
