Mysql insert for column with enumerated values?
I have an insert that works, until i try to send a field that is type enum. The value that’s being sent is in the enumerated fields in the database. It’s for states, so TN is in the value set and that’s also a value in the ENUM list. However I get this error with n8n when trying to insert:
NodeOperationError: Data truncated for column 'clState' at row 2 at Object.parseMySqlError (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/MySql/v2/helpers/utils.js:74:12) at /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/MySql/v2/helpers/utils.js:171:47 at processTicksAndRejections (node:internal/process/task_queues:95:5) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/MySql/v2/actions/database/insert.operation.js:171:18) at Object.router (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/MySql/v2/actions/router.js:53:30) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/MySql/v2/MySqlV2.node.js:16:16) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:728:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:660:53 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1062:20
n8n 1.38.2
self hosted mysql database (n8n is using it’s default)
Docker
Ubuntu 22.04lts
Hi @tkintenn, could you share the exported JSON for the MySQL node you’re doing this with? You can do so by copy & pasting the workflow JSON content in between two block quotes (```)
Also, it might be helpful if you could share additional info like the following,
  1. The full schema of the table. You can get this by running the following SQL command:
    SHOW CREATE TABLE name_of_table;
  2. The exact ENUM definition for the clState column:
    SHOW COLUMNS FROM name_of_table LIKE 'clState';
I’m trying to paste the output from mysql and keep getting a 403 error.
clState | enum(‘AL’,‘AK’,‘AZ’,‘AR’,‘CA’,‘CO’,‘CT’,‘DE’,‘DC’,‘FL’,‘GA’,‘HI’,‘ID’,‘IL’,‘IN’,‘IA’,‘KA’,‘KY’,‘LA’,‘ME’,‘MD’,‘MA’,‘MI’,‘MN’,‘MS’,‘MO’,‘MT’,‘NE’,‘NV’,‘NH’,‘NJ’,‘NM’,‘NY’,‘NC’,‘ND’,‘OH’,‘OK’,‘OR’,‘PA’,‘RI’,‘SC’,‘SD’,‘TN’,‘TX’,‘UT’,‘VT’,‘VA’,‘WA’,‘WV’,‘WI’,‘WY’) | YES | | NULL | |
