STEP 1) I am using the mySQL module to query unique records by ID
STEP 2) I am using the mySQL module to utilize the ID from step 1 to query related records. The output from this step could be 1 or more than one related record
STEP 3) I am taking the output from Step 2 and converted it into an HTML Table
STEP 4) I am sending an email with the output from Step 3
The PROBLEM that I am having is that Step 2 output’s ALL data for all ID’s, and then sends ALL ID’s from Step 1 into Step 2 in a single run. As a result the table in Step 3 is a list of ALL data from Step 2. Instead, I need individual tables by ID from Step 2.
I am coming transitioning this workflow from Make and I am taking for granted some of the features of Make where runs are split into separate batches.
You can see in the image above that Step 1 produced 2 items. These 2 items are 2 unique ID’s. Step 2 produces 7 items, but 4 items are related to one ID and 3 items are related a second ID. See further below.
Essentially I need Step 3 to produce two tables. One for the related records of the first unique ID and another for the related records of the second ID. And I need this process to iterate until ID N…
- n8n version: 1.57
- Database: default: SQLite
- Running n8n via: Docker
- Operating system: Ubuntu
