Hi, I’m getting this message when I try to startup my containers:
(node:6) UnhandledPromiseRejectionWarning: Error: There was an error: Connections using insecure transport are prohibited while --require_secure_transport=ON.
at Object.error (/usr/local/lib/node_modules/n8n/node_modules/@oclif/errors/lib/index.js:22:17)
at Start.error (/usr/local/lib/node_modules/n8n/node_modules/@oclif/command/lib/command.js:60:23)
at /usr/local/lib/node_modules/n8n/dist/commands/start.js:114:22
at processTicksAndRejections (internal/process/task_queues.js:97:5)
(node:6) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v17.8.0 Documentation). (rejection id: 1)
(node:6) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
Anyone have a clue how do I make my n8n connection secure? since I have followed the setup my server guide and using a LetsEncrypt certificate I hoped my connection would already be secured.
