N8n 1.33.0 Init Problem There was a problem loading init data: Unauthorized
Hello, when updating n8n from version 1.30.0 to 133.0, a login error occurs
I’m using Docker with Postgres
Follow my docker compose code
version: '3.8'
volumes:
  db_storage:
  n8n_storage:
services:
  postgres:
    image: postgres:16
    restart: always
    environment:
      - POSTGRES_USER
      - POSTGRES_PASSWORD
      - POSTGRES_DB
      - POSTGRES_NON_ROOT_USER
      - POSTGRES_NON_ROOT_PASSWORD
    volumes:
      - db_storage:/var/lib/postgresql/data
      - ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
    healthcheck:
      test: ['CMD-SHELL', 'pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}']
      interval: 5s
      timeout: 5s
      retries: 10
  n8n:
    image: docker.n8n.io/n8nio/n8n:1.30.0
    restart: always
    environment:
      - DB_TYPE=postgresdb
      - DB_POSTGRESDB_HOST=postgres
      - DB_POSTGRESDB_PORT=5432
      - DB_POSTGRESDB_DATABASE=${POSTGRES_DB}
      - DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
      - DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
      - GENERIC_TIMEZONE=America/Sao_Paulo
    ports:
      - 5678:5678
    links:
      - postgres
    volumes:
      - n8n_storage:/home/node/.n8n
    depends_on:
      postgres:
        condition: service_healthy
hello @Larri_Benedetti
I do not see that you have configured https, so that workaround should help
I am getting the same error, I am using the Postgres with a worker docker compose instance. I had n8n running perfectly fine up until last month, but when I updated my container, my “docker-compose.yml” and my “init-data.sh”, I started having some errors.
Already tried using:
• user-management:reset
• ldap:reset
• using an earlier commit of init-data.sh
But no to no avail, any ideas?
Have you tried to set the N8N_SECURE_COOKIE?
Yes, I just tried setting N8N_SECURE_COOKIE=FALSE on my .env file and I am still getting the “Init Error” followed by “Error while submitting results”.
I am also getting “WARN[0000] /root/docker/docker-compose.yml: version is obsolete” which I don’t believe it was there before I updated n8n.
Edit: So I was setting up the N8N_SECURE_COOKIE on my .env file instead of configuring like this page shows. Setting the cookie to false worked for me, thank you.
So not sure if this is a consequence of setting N8N_SECURE_COOKIE to false, but now I can’t log in to my google drive account, I get {“status”: “error”, “message”: “Unauthorized” }, again this was working perfectly fine before the update.
maybe your token is expired?
