N8n Bedrock Integration Issues
“Unexpected value type in payload”: Debugging Amazon Bedrock + n8n (with Claude 3.5)
Recently I wired up an evaluation pipeline in n8n using Amazon Bedrock (Anthropic Claude 3.5 Sonnet).
The goal was simple:
  1. Upload a consulting slide deck (PDF)
  2. Extract the text
  3. Send it to Bedrock to score the deck against a rubric
  4. Store the scores + human ratings in Airtable for comparison
Everything worked… until I replaced my tiny “hello” prompt with a real multi-line rubric. Then Bedrock started returning:
If you’re trying to call Bedrock from n8n and keep hitting this error, this post walks through:
  • What causes it (in a very real, painful example)
  • How to structure the messages payload correctly
  • How to handle multi-line prompts and large text (like PDF content)
  • How to avoid n8n JSON pitfalls
The working baseline: a tiny prompt
In n8n, I used an HTTP Request node pointing to Bedrock’s invoke endpoint, with a minimal body like this:
  "messages": [
      "role": "user",
      "content": [
        { "text": "Say hello Claude 4.5 Sonnet." }
  "inferenceConfig": {
    "maxTokens": 1500
  • Method: POST
  • Content-Type: application/json
  • Body: JSON mode in n8n
This worked perfectly. Bedrock replied with a nice “hello”.
So far so good.
When everything broke: adding the real rubric
Next I swapped the tiny prompt for a big evaluation rubric: scoring clear objective, logical flow, visual design, etc.
I pasted something like this inside "text": "...":
You are an expert evaluator of consulting presentation decks...
OUTPUT FORMAT (STRICT JSON)
Return ONLY the following JSON:
  "Clear Objective": { "score": 0.0|0.5|1.0, "justification": "...", "evidence": "..." },
  "Logical Flow": { "score": 0.0|0.5|1.0, "justification": "...", "evidence": "..." },
  "Total Score": <sum of all scores>,
  "Summary": "<2–3 sentence high-level summary of the deck’s quality>"
Same structure, just a bigger prompt.
Suddenly Bedrock started throwing:
Changing the model, reducing maxTokens, etc. didn’t help. But a one-line prompt still worked.
So what was going on?
Root cause #1: invalid JSON inside your JSON
The key mistake: I dropped a JSON example inside the "text" string without escaping anything.
From Bedrock’s perspective, the body looked roughly like:
  "messages": [
      "role": "user",
      "content": [
          "text": "Return ONLY the following JSON:
Notice the problem:
  • Inside the "text" value, there are unescaped double quotes ("Clear Objective", "score", etc.)
  • That breaks the outer JSON. n8n sends malformed JSON → Bedrock says “unexpected value type”.
How to fix it
You have three options:
  1. Don’t embed JSON at all.
    Describe the structure instead:
    Return a JSON object with the following keys:
    • "Clear Objective" with fields "score", "justification", "evidence"
    • "Logical Flow" with fields "score", "justification", "evidence"
  2. Use single quotes inside the example and keep double quotes only for the outer JSON string (less strict but often enough).
  3. Properly escape the inner quotes (e.g., \"Clear Objective\") – but this gets messy fast, especially in n8n’s JSON editor.
In practice, option 1 is the cleanest: describe the JSON rather than pasting a raw JSON template.
Root cause #2: multi-line prompts in n8n’s JSON editor
The other thing that confused me: when I had a long, multi-line prompt, errors became harder to reason about.
The trick that made everything stable:
Build the prompt in a Code node and send it as data, not as raw JSON text
Instead of fighting with huge strings in the HTTP node, I switched to this pattern:
  1. Extract PDF text (via the Extract from File node).
  2. In a Code (JavaScript) node, build a clean prompt:
    const deckText = $item(0).$node["Extract from File"].json.text;
    const rubricPrompt = `
You are an expert evaluator of consulting presentation decks…
SCORING RULES
1.0 = Outstanding …
0.5 = Basic …
0.0 = Poor …
EVALUATION CRITERIA
  1. Clear Objective — …
  2. Logical Flow — …
DECK TEXT TO EVALUATE
${deckText}
`.trim();
return [
json: {
messages: [
role: “user”,
content: [
{ text: rubricPrompt }
inferenceConfig: {
maxTokens: 1500
3. In the **HTTP Request (Bedrock)** node:
- Body mode: **JSON**
- Click the little gear → **Add Expression**
- Use: `={{ $json }}` so the node sends exactly the object produced by the Code node.
Now:
- n8n never has to parse a giant JSON literal with embedded quotes.
- The prompt can have as many line breaks as you want.
- You can inject the deck text with `${deckText}` safely.
## Correct Bedrock payload structure (for Claude 3.5 via n8n)
This is the structure that works reliably:
```json
"messages": [
   "role": "user",
   "content": [
     { "text": "full prompt including rubric and deck text..." }
 "maxTokens": 1500
Key things to watch:
  • messages is an array
  • Each message has a role ("user", "assistant", etc.)
  • content is an array of objects, each with "text"
    (Bedrock’s API wrapper handles the type: "text" part under the hood)
  • No extra wrapper JSON like "anthropic_version" if you’re using the Bedrock runtime style you get from the console’s Test feature.
This error typically occurs when the Bedrock API receives malformed JSON or unexpected data types in the payload. For multi-line prompts, you’ll need to properly escape the content and ensure the JSON structure matches Bedrock’s requirements exactly.
Try this:
1. Use the “Code” node to properly format your multi-line prompt as a JSON string
2. Validate your payload structure against Bedrock’s API docs
3. Consider breaking large PDF content into smaller chunks if hitting size limits
The issue is often subtle formatting differences in how n8n handles JSON vs what Bedrock expects.
