hello everyone, maybe someone knows if it is possible to send a ready-made prompt, for example, sent by the user through a form, and have it automatically sent to the javascript ask AI parameter. That is, to automate the transmission of the prompt not manually, but through a link to the value in the form. I will be grateful for the answer ![]()
- n8n version:
- Database (default: SQLite):
- Operating system:
I’m a bit confused about what you’re asking - do you just want to pass a form value to an agent at the prompt?
no, don’t be scared, I’m looking for an option that can automatically send a hint directly to the CODE node without using an AI agent
