N8n Compute Engine instance randomly crashes
Our VM running in Compute Engine in GCP using the standard docker images crashes from time to time, when this happens we completely lose access to the VM and we need to reset the VM and the services to continue operating
Our question is, is this a known issue? what type of deployment do you recommend in GCP?
  • We have tried Cloud Run but it does not work well, this is a known limitation because n8n does not support the main instance scaling
  • We have tried Compute Engine with the issue described in this post to no success
What else can we do? We don’t have anyone in the team with enough infrastructure experience that can perform the Kubernetes installation
We are open to explore something like
  • Main instance running in Compute Engine
  • Workers running in Cloud Run (for scaling) although I haven’t found docs on how to do this exactly
The only exception I see in the logs is the following
DEFAULT 2023-04-05T23:16:29.301636334Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] Initializing n8n process
DEFAULT 2023-04-05T23:16:39.831220219Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] (node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 editorUiConnected listeners added to [MessageEventBus]. Use emitter.setMaxListeners() to increase limit
DEFAULT 2023-04-05T23:16:39.831373443Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] (Use `node --trace-warnings ...` to show where the warning was created)
DEFAULT 2023-04-05T23:16:39.873698472Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] n8n ready on 0.0.0.0, port 5678
N/A
N/A
  • n8n version: n8nio/n8n:0.219.1
  • Database (default: SQLite): Postgres 13
    Distributor ID: Ubuntu
    Description: Ubuntu 20.04.4 LTS
    Release: 20.04
    Codename: focal
Also may be related to this one?
Hey @nahueld,
There shouldn’t be any issues with n8n in GCP with Compute, Have you checked the compute logs when it crashes? Docker crashing or locking up shouldn’t cause the VM to stop working so it sounds like there could be a bit to it.
Yes, the compute logs are the ones in the ticket, they talk about some memory leak but they don’t add much more information
Hey @nahueld,
They looked like docker logs to me rather than compute OS logs. Can you confirm how you got the logs?
Correct these are the docker logs I’m sending to Cloud Logging, the VM is running the docker image
It has been a while since I have used compute but does that give you access to the OS itself to install docker and load the image on or does it directly run a docker image?
It gives you access to the OS, there you can install docker and on top of that run the containers, we are currently using a pre-built image on the VM called “Docker Compose Server on Ubuntu Server 20.04”, and the VM specs are
VM instance: 1 vCPU + 3.75 GB memory
Standard Persistent Disk: 10GB
Something I noticed before the instance crashes is the following
DEFAULT 2023-04-19T20:16:34.234218061Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: SELECT "SharedWorkflow"."workflowId" AS "SharedWorkflow_workflowId", "SharedWorkflow"."userId" AS "SharedWorkflow_userId", "SharedWorkflow__SharedWorkflow_workflow"."createdAt" AS "SharedWorkflow__SharedWorkflow_workflow_createdAt", "SharedWorkflow__SharedWorkflow_workflow"."updatedAt" AS "SharedWorkflow__SharedWorkflow_workflow_updatedAt", "SharedWorkflow__SharedWorkflow_workflow"."id" AS "SharedWorkflow__SharedWorkflow_workflow_id", "SharedWorkflow__SharedWorkflow_workflow"."name" AS "SharedWorkflow__SharedWorkflow_workflow_name", "SharedWorkflow__SharedWorkflow_workflow"."active" AS "SharedWorkflow__SharedWorkflow_workflow_active", "SharedWorkflow__SharedWorkflow_workflow"."nodes" AS "SharedWorkflow__SharedWorkflow_workflow_nodes", "SharedWorkflow__SharedWorkflow_workflow"."connections" AS "SharedWorkflow__SharedWorkflow_workflow_connections", "SharedWorkflow__SharedWorkflow_workflow"."settings" AS "SharedWorkflow__SharedWorkflow_workflow_settings", "SharedWorkflow__SharedWorkflow_workflow"."staticData" AS "SharedWorkflow__SharedWorkflow_workflow_staticData", "SharedWorkflow__SharedWorkflow_workflow"."pinData" AS "SharedWorkflow__SharedWorkflow_workflow_pinData", "SharedWorkflow__SharedWorkflow_workflow"."versionId" AS "SharedWorkflow__SharedWorkflow_workflow_versionId", "SharedWorkflow__SharedWorkflow_workflow"."triggerCount" AS "SharedWorkflow__SharedWorkflow_workflow_triggerCount", "SharedWorkflow__SharedWorkflow_role"."createdAt" AS "SharedWorkflow__SharedWorkflow_role_createdAt", "SharedWorkflow__SharedWorkflow_role"."updatedAt" AS "SharedWorkflow__SharedWorkflow_role_updatedAt", "SharedWorkflow__SharedWorkflow_role"."id" AS "SharedWorkflow__SharedWorkflow_role_id", "SharedWorkflow__SharedWorkflow_role"."name" AS "SharedWorkflow__SharedWorkflow_role_name", "SharedWorkflow__SharedWorkflow_role"."scope" AS "SharedWorkflow__SharedWorkflow_role_scope" FROM "n8n2"."shared_workflow" "SharedWorkflow" LEFT JOIN "n8n2"."workflow_entity" "SharedWorkflow__SharedWorkflow_workflow" ON "SharedWorkflow__SharedWorkflow_workflow"."id"="SharedWorkflow"."workflowId" LEFT JOIN "n8n2"."role" "SharedWorkflow__SharedWorkflow_role" ON "SharedWorkflow__SharedWorkflow_role"."id"="SharedWorkflow"."roleId"
DEFAULT 2023-04-19T20:16:34.270483125Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1337
DEFAULT 2023-04-19T20:16:34.308839587Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: SELECT COUNT(1) AS "cnt" FROM "n8n2"."execution_entity" "ExecutionEntity" WHERE ("ExecutionEntity"."workflowId" = $1 AND NOT("ExecutionEntity"."id" IN ($2, $3, $4, $5, $6, $7, $8, $9, $10))) -- PARAMETERS: [70,"87824","87825","87826","87827","87828","87829","87830","87831","87832"]
DEFAULT 2023-04-19T20:16:34.322493899Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1211
DEFAULT 2023-04-19T20:16:34.335499143Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: SELECT COUNT(1) AS "cnt" FROM "n8n2"."execution_entity" "ExecutionEntity" WHERE ("ExecutionEntity"."workflowId" = $1 AND NOT("ExecutionEntity"."id" IN ($2, $3, $4, $5, $6, $7, $8, $9, $10))) -- PARAMETERS: [70,"87824","87825","87826","87827","87828","87829","87830","87831","87832"]
DEFAULT 2023-04-19T20:16:34.338461066Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1017
DEFAULT 2023-04-19T20:16:34.620172585Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: SELECT "execution"."id" AS "execution_id", "execution"."finished" AS "execution_finished", "execution"."mode" AS "execution_mode", "execution"."retryOf" AS "execution_retryOf", "execution"."retrySuccessId" AS "execution_retrySuccessId", "execution"."status" AS "execution_status", "execution"."startedAt" AS "execution_startedAt", "execution"."stoppedAt" AS "execution_stoppedAt", "execution"."workflowData" AS "execution_workflowData", "execution"."waitTill" AS "execution_waitTill" FROM "n8n2"."execution_entity" "execution" WHERE ("execution"."workflowId" IN ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $18, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30, $31, $32, $33, $34, $35, $36, $37, $38, $39, $40, $41, $42, $43, $44, $45, $46, $47, $48, $49, $50, $51, $52, $53, $54, $55, $56, $57, $58) AND id NOT IN ($59, $60, $61, $62, $63, $64, $65, $66)) AND "execution"."workflowId" = $67 ORDER BY id DESC LIMIT 20 -- PARAMETERS: ["49","50","51","52","53","54","55","56","8","11","14","15","16","19","22","23","24","26","27","31","33","34","37","40","42","44","2","3","5","7","9","10","20","21","29","32","36","38","39","41","43","45","46","48","57","59","60","61","62","63","65","66","67","68","69","70","71","72","87825","87826","87827","87828","87829","87830","87831","87832",70]
DEFAULT 2023-04-19T20:16:34.644474369Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1020
DEFAULT 2023-04-19T20:16:34.648557704Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: UPDATE "n8n2"."workflow_statistics" SET "count" = count + 1, "latestEvent" = $1 WHERE ("workflowId" = $2 AND "name" = $3) -- PARAMETERS: ["2023-04-19T20:16:33.566Z",11,"production_success"]
DEFAULT 2023-04-19T20:16:34.678505532Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1045
DEFAULT 2023-04-19T20:16:34.858951238Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: SELECT "SharedWorkflow"."workflowId" AS "SharedWorkflow_workflowId", "SharedWorkflow"."userId" AS "SharedWorkflow_userId", "SharedWorkflow__SharedWorkflow_workflow"."createdAt" AS "SharedWorkflow__SharedWorkflow_workflow_createdAt", "SharedWorkflow__SharedWorkflow_workflow"."updatedAt" AS "SharedWorkflow__SharedWorkflow_workflow_updatedAt", "SharedWorkflow__SharedWorkflow_workflow"."id" AS "SharedWorkflow__SharedWorkflow_workflow_id", "SharedWorkflow__SharedWorkflow_workflow"."name" AS "SharedWorkflow__SharedWorkflow_workflow_name", "SharedWorkflow__SharedWorkflow_workflow"."active" AS "SharedWorkflow__SharedWorkflow_workflow_active", "SharedWorkflow__SharedWorkflow_workflow"."nodes" AS "SharedWorkflow__SharedWorkflow_workflow_nodes", "SharedWorkflow__SharedWorkflow_workflow"."connections" AS "SharedWorkflow__SharedWorkflow_workflow_connections", "SharedWorkflow__SharedWorkflow_workflow"."settings" AS "SharedWorkflow__SharedWorkflow_workflow_settings", "SharedWorkflow__SharedWorkflow_workflow"."staticData" AS "SharedWorkflow__SharedWorkflow_workflow_staticData", "SharedWorkflow__SharedWorkflow_workflow"."pinData" AS "SharedWorkflow__SharedWorkflow_workflow_pinData", "SharedWorkflow__SharedWorkflow_workflow"."versionId" AS "SharedWorkflow__SharedWorkflow_workflow_versionId", "SharedWorkflow__SharedWorkflow_workflow"."triggerCount" AS "SharedWorkflow__SharedWorkflow_workflow_triggerCount", "SharedWorkflow__SharedWorkflow_role"."createdAt" AS "SharedWorkflow__SharedWorkflow_role_createdAt", "SharedWorkflow__SharedWorkflow_role"."updatedAt" AS "SharedWorkflow__SharedWorkflow_role_updatedAt", "SharedWorkflow__SharedWorkflow_role"."id" AS "SharedWorkflow__SharedWorkflow_role_id", "SharedWorkflow__SharedWorkflow_role"."name" AS "SharedWorkflow__SharedWorkflow_role_name", "SharedWorkflow__SharedWorkflow_role"."scope" AS "SharedWorkflow__SharedWorkflow_role_scope" FROM "n8n2"."shared_workflow" "SharedWorkflow" LEFT JOIN "n8n2"."workflow_entity" "SharedWorkflow__SharedWorkflow_workflow" ON "SharedWorkflow__SharedWorkflow_workflow"."id"="SharedWorkflow"."workflowId" LEFT JOIN "n8n2"."role" "SharedWorkflow__SharedWorkflow_role" ON "SharedWorkflow__SharedWorkflow_role"."id"="SharedWorkflow"."roleId"
DEFAULT 2023-04-19T20:16:34.859498068Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1180
DEFAULT 2023-04-19T20:16:35.012477455Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: SELECT "SharedWorkflow"."workflowId" AS "SharedWorkflow_workflowId", "SharedWorkflow"."userId" AS "SharedWorkflow_userId", "SharedWorkflow__SharedWorkflow_workflow"."createdAt" AS "SharedWorkflow__SharedWorkflow_workflow_createdAt", "SharedWorkflow__SharedWorkflow_workflow"."updatedAt" AS "SharedWorkflow__SharedWorkflow_workflow_updatedAt", "SharedWorkflow__SharedWorkflow_workflow"."id" AS "SharedWorkflow__SharedWorkflow_workflow_id", "SharedWorkflow__SharedWorkflow_workflow"."name" AS "SharedWorkflow__SharedWorkflow_workflow_name", "SharedWorkflow__SharedWorkflow_workflow"."active" AS "SharedWorkflow__SharedWorkflow_workflow_active", "SharedWorkflow__SharedWorkflow_workflow"."nodes" AS "SharedWorkflow__SharedWorkflow_workflow_nodes", "SharedWorkflow__SharedWorkflow_workflow"."connections" AS "SharedWorkflow__SharedWorkflow_workflow_connections", "SharedWorkflow__SharedWorkflow_workflow"."settings" AS "SharedWorkflow__SharedWorkflow_workflow_settings", "SharedWorkflow__SharedWorkflow_workflow"."staticData" AS "SharedWorkflow__SharedWorkflow_workflow_staticData", "SharedWorkflow__SharedWorkflow_workflow"."pinData" AS "SharedWorkflow__SharedWorkflow_workflow_pinData", "SharedWorkflow__SharedWorkflow_workflow"."versionId" AS "SharedWorkflow__SharedWorkflow_workflow_versionId", "SharedWorkflow__SharedWorkflow_workflow"."triggerCount" AS "SharedWorkflow__SharedWorkflow_workflow_triggerCount", "SharedWorkflow__SharedWorkflow_role"."createdAt" AS "SharedWorkflow__SharedWorkflow_role_createdAt", "SharedWorkflow__SharedWorkflow_role"."updatedAt" AS "SharedWorkflow__SharedWorkflow_role_updatedAt", "SharedWorkflow__SharedWorkflow_role"."id" AS "SharedWorkflow__SharedWorkflow_role_id", "SharedWorkflow__SharedWorkflow_role"."name" AS "SharedWorkflow__SharedWorkflow_role_name", "SharedWorkflow__SharedWorkflow_role"."scope" AS "SharedWorkflow__SharedWorkflow_role_scope" FROM "n8n2"."shared_workflow" "SharedWorkflow" LEFT JOIN "n8n2"."workflow_entity" "SharedWorkflow__SharedWorkflow_workflow" ON "SharedWorkflow__SharedWorkflow_workflow"."id"="SharedWorkflow"."workflowId" LEFT JOIN "n8n2"."role" "SharedWorkflow__SharedWorkflow_role" ON "SharedWorkflow__SharedWorkflow_role"."id"="SharedWorkflow"."roleId"
DEFAULT 2023-04-19T20:16:35.030470419Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1327
DEFAULT 2023-04-19T20:16:35.483835412Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] allWorkOrders { json: { records: [] }, pairedItem: { item: 0, input: undefined } }
DEFAULT 2023-04-19T20:16:35.494819237Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] []
DEFAULT 2023-04-19T20:16:44.983636497Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: SELECT "User"."createdAt" AS "User_createdAt", "User"."updatedAt" AS "User_updatedAt", "User"."id" AS "User_id", "User"."email" AS "User_email", "User"."firstName" AS "User_firstName", "User"."lastName" AS "User_lastName", "User"."password" AS "User_password", "User"."resetPasswordToken" AS "User_resetPasswordToken", "User"."resetPasswordTokenExpiration" AS "User_resetPasswordTokenExpiration", "User"."personalizationAnswers" AS "User_personalizationAnswers", "User"."settings" AS "User_settings", "User"."globalRoleId" AS "User_globalRoleId", "User"."disabled" AS "User_disabled", "User"."apiKey" AS "User_apiKey", "User__User_globalRole"."createdAt" AS "User__User_globalRole_createdAt", "User__User_globalRole"."updatedAt" AS "User__User_globalRole_updatedAt", "User__User_globalRole"."id" AS "User__User_globalRole_id", "User__User_globalRole"."name" AS "User__User_globalRole_name", "User__User_globalRole"."scope" AS "User__User_globalRole_scope" FROM "n8n2"."user" "User" LEFT JOIN "n8n2"."role" "User__User_globalRole" ON "User__User_globalRole"."id"="User"."globalRoleId" WHERE ( ("User"."id" = $1) ) AND ( "User"."id" IN ($2) ) -- PARAMETERS: ["9c7abeda-4230-4ce3-ba51-c903a32f2fce","9c7abeda-4230-4ce3-ba51-c903a32f2fce"]
DEFAULT 2023-04-19T20:16:44.994493594Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1521
DEFAULT 2023-04-19T20:16:49.277532139Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] query is slow: SELECT "ExecutionEntity"."id" AS "ExecutionEntity_id", "ExecutionEntity"."data" AS "ExecutionEntity_data", "ExecutionEntity"."finished" AS "ExecutionEntity_finished", "ExecutionEntity"."mode" AS "ExecutionEntity_mode", "ExecutionEntity"."retryOf" AS "ExecutionEntity_retryOf", "ExecutionEntity"."retrySuccessId" AS "ExecutionEntity_retrySuccessId", "ExecutionEntity"."status" AS "ExecutionEntity_status", "ExecutionEntity"."startedAt" AS "ExecutionEntity_startedAt", "ExecutionEntity"."stoppedAt" AS "ExecutionEntity_stoppedAt", "ExecutionEntity"."workflowData" AS "ExecutionEntity_workflowData", "ExecutionEntity"."workflowId" AS "ExecutionEntity_workflowId", "ExecutionEntity"."waitTill" AS "ExecutionEntity_waitTill" FROM "n8n2"."execution_entity" "ExecutionEntity" WHERE ("ExecutionEntity"."id" = $1) LIMIT 1 -- PARAMETERS: [55792]
DEFAULT 2023-04-19T20:16:49.282455032Z [resource.labels.instanceId: docker-compose-n8n-vm-vm] execution time: 1413
There is a series of slow queries and my theory is that these build up memory usage, do you know why could this be the case?
Hi @nahueld
Have a look at this: Workflow on worker taking a lot more memory than on main - #12 by netroy
