We Have Integrated n8n in docker and when we deployed n8n in server. After Some time it is taking resource utilization 150% in server. How to optimize this utilization of n8n.
This will depend greatly on how you’re using n8n and even in how you are managing your Docker container resource limits and allocations.
If, for example you are running something 200 executions at the same time, it would be worth considering creating a second or third instances and dividing the load between them.
You could also go over how you manage your workflows. Implementing a timeout option, for example; rethinking how efficient each workflow is and maybe rearanging the node number or data processing steps.
Here is n8n’s documentation on how to manage your self-hosted instance as it scales and needs more resources: Overview | n8n Docs
