N8N docker origin header issue
Hello N8N experts
I’m a beginner with N8N but find it very versatile. I’ve managed to install it on a local Docker Desktop environnement on my computer.
Now I’m trying to host it on a docker server with the use of named URL’s instead of localhost.
The installation was ok and I’ve managed to activate the licence key from the web admin.
But when I go inside a new workflow, I’ve noticed in the right upper corner an error of connection.
Digging inside my container logs revealed a recurrent issue
Origin header does NOT match the expected origin. (Origin: “https://n8n.mysite.com”, Expected: “wss://n8n.,mysite.com”)
Information on my n8n setup
  • n8n version: 1.95.2
  • Database posgresql
  • Running n8n via Docker
  • Operating system Ubuntu
Many thanks in advance
Did you use à docker-compose.yml or the docker image from the repo ?
Hello,
I finally find the solution in another post :
The problem was the docker URL in my compose file. I was unable to get the latest version.
It was :
  • image: docker.n8n.io/n8nio/n8n
instead of the correct one :
  • image: n8nio/n8n
What’s the difference between this 2 URL’s ?
Thanks
Docker desktop ??
on the server it’s Docker version 28.1.1, build 4eba377
Command line or GUI ? Maybe the management is different.
