The following workflow should not give an error, as far as I know:
“No Webhook node found in the workflow”.
This is very weird, because as far as I understand, the n8n Form Trigger node should be enough, no?
- n8n version: 1.38.1
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Operating system: Linux
n8n
2
- n8n version:
- Operating system:
I am experiencing the same behaviour even though I’ve added an Edit Field
node in between.
Yes, my actual workflow has other nodes in between, and also has this issue. This is the minimum non-working example.
cahva
5
system
Closed
6
