I have a json payload that comes as input to a filter.
Filter has to look at the input and only pass json objects which don’t have values like (a|b|c|d)
I have put regex in filter node with operation ‘Regex Not Match’ on the input string
exact regex I put in : /(Unknown|unknown|value|not provided)/
I am assuming I m making syntax error while feeding in the regex, please let me know how to write a proper regex in n8n as I was not able to find any documentation online.
Error that I am getting is that unwanted values are moving forward from the filter
“meta”: {
“instanceId”: “b21c5c764b1c163869f34ac65ce947166061ef1893d05087f4d6fedc65f1229b”
“nodes”: [
“parameters”: {
“conditions”: {
“string”: [
“value1”: “={{ JSON.parse($json["message"]["content"]).department }}”,
“operation”: “isNotEmpty”
“operation”: “notRegex”,
“value2”: “/(Unknown|unknown|value)/”
“id”: “4ce4c87f-8c44-4d6b-bfd8-83d0da112c93”,
“name”: “Filter SYL response empty1”,
“type”: “n8n-nodes-base.filter”,
“typeVersion”: 1,
“position”: [
900,
1280
“connections”: {},
“pinData”: {}
- n8n version:
- Database (default: SQLite):
- Operating system:
