N8n kafka trigger node execution stuck in running status
i have a simple workflow, kafka trigger node → do nothing node.
using MAC OS Ventura 13.5, i have kafka installed via homebrew as service.
using built-in kafka console producer with command:
kafka-console-producer --topic kafka-deep-dive --bootstrap-server localhost:9092
just feeding a simple event copy/paste enter:
{“id”: 1}
{“id”: 1}
{“id”: 1}
{“id”: 1}
{“id”: 1}
{“id”: 1}
{“id”: 1}
{“id”: 1}
when i do the copy-paste-enter quickly multiple times, sometimes executions get stuck with status running. i am assuming its not a n8n-gui related problem, i also checked with
select * from execution_entity ee where ee.“workflowId” = ‘9WaZ2DgfbBMoRGqI’ and ee.status <> ‘success’;
i can see executions with status running.
Any ideas ?
## Share the output returned by the last node
<!-- If you need help with data transformations, please also share your expected output. -->
- **n8n version:** 1.8.2
- **Database (default: SQLite):** postgresql
- **n8n EXECUTIONS_PROCESS setting (default: own, main):** main
- **Running n8n via (Docker, npm, n8n cloud, desktop app):** npm
- **Operating system:** MAC OS 13.5
Hi @slenderwrist, I am sorry you’re having trouble. I tried reproducing this but was unable to do so.
Do you see any errors in your server logs?
