See the below n8n flow. My question is linked to the Loop Over Items step: How do I make sure, in subsequent HTTP calls in this case, I leverage the id values provided in the loop call ?
For example, in my code, I am able to loop on items of the LOOP node in the Get Survey Details and Get Survey/surveyCampaign HTTP nodes. The Get Survey/surveyCampaign/surveyContact node however only picks the last loop value (the value assigned to {{ $(‘Get Survey Details’).item.json.data.id }} in the node) instead of picking the same id used in the two previous nodes.
What is the error message (if any)? n\a
Error since not picking the LOOP id value
- **n8n version:1.24.1
- **Database (default: SQLite):n\a
- **n8n EXECUTIONS_PROCESS setting (default: own, main): own
- **Running n8n via (Docker, npm, n8n cloud, desktop app):docker
- **Operating system:Unix
