I have this node system where it paginates customer data.
When it goes to the 2nd page (getting its 6th to 10th) data, suddenly it stopped at the split-in-batches data.
There’s no error message.
I have made sure that the split-in-batches data is not executed once.
That is because the splitinbatches node has a boolean variable that tells it if it is done or not. The same you also use in the IF node.
This does not get reset the second time so it thinks it is done.
Only way to do this is, would be a subworkflow I think.
