Probled Description:
We have allocated 2 core & 4 GB RAM with 10 workflows and in that a single workflow will run at every 1 minute once. Here we are facing load issue frequently twice a day or even daily once.
Observation:
When we monitored closely we came to know that node process ie., the workflow process is the cause of load issue.
Requested For:
We required to know is there any solution to monitor which workflow node process causing this load issue since we are unable to pick from the list of process
Note: The n8n is running as a docker container.
Thanks!
- n8n version: 0.225.2
- Database (default: SQLite): mysql
Docker ENV
- EXECUTIONS_MODE=queue
- QUEUE_BULL_REDIS_HOST=redis
- Operating system: Alpine Linux v3.17
- Base Machine OS Ubuntu 22.04
