N8n nodes imap - installation problem
Hi, I have a problem. I can’t install https://www.npmjs.com/package/n8n-nodes-imap - it keeps showing me the problem as shown on the screen. I’ve already tried directly through Docker, but the installation was unsuccessful.
What can I do?
The error I get in the N8N UI is "Error installing new package
Error loading package “n8n-nodes-imap” :The specified package could not be loaded Cause: Class could not be found. Please check if the class is named correctly."
See:
Thanks :slight_smile: I got it :slight_smile:
