N8n not accessible when using custom IPvlan network
n8n not accessible when using custom IPvlan network
Hello everyone,
I’m trying to set up n8n using Docker Compose together with Traefik for reverse proxy.
I followed the official documentation up to step 5 successfully.
Before step 6, I made a change — I wanted to use my own IPvlan network instead of the default Docker bridge network.
Here’s how I created the IPvlan network:
sudo docker network create -d ipvlan
–subnet 192.168.1.0/24
–gateway 192.168.1.1
-o parent=ens34
ipvlannetwork
And here is my docker-compose.yml file:
services:
  traefik:
    image: "traefik"
    restart: always
    command:
      - "--api.insecure=true"
      - "--providers.docker=true"
      - "--providers.docker.exposedbydefault=false"
      - "--entrypoints.web.address=:80"
      - "--entrypoints.web.http.redirections.entryPoint.to=websecure"
      - "--entrypoints.web.http.redirections.entrypoint.scheme=https"
      - "--entrypoints.websecure.address=:443"
      - "--certificatesresolvers.mytlschallenge.acme.tlschallenge=true"
      - "--certificatesresolvers.mytlschallenge.acme.email=${SSL_EMAIL}"
      - "--certificatesresolvers.mytlschallenge.acme.storage=/letsencrypt/acme.json"
    volumes:
      - traefik_data:/letsencrypt
      - /var/run/docker.sock:/var/run/docker.sock:ro
    networks:
      ipvlannetwork:
        ipv4_address: 192.168.1.77
  n8n:
    image: docker.n8n.io/n8nio/n8n
    restart: always
    labels:
      - traefik.enable=true
      - traefik.http.routers.n8n.rule=Host(`${SUBDOMAIN}.${DOMAIN_NAME}`)
      - traefik.http.routers.n8n.tls=true
      - traefik.http.routers.n8n.entrypoints=web,websecure
      - traefik.http.routers.n8n.tls.certresolver=mytlschallenge
      - traefik.http.middlewares.n8n.headers.SSLRedirect=true
      - traefik.http.middlewares.n8n.headers.STSSeconds=315360000
      - traefik.http.middlewares.n8n.headers.browserXSSFilter=true
      - traefik.http.middlewares.n8n.headers.contentTypeNosniff=true
      - traefik.http.middlewares.n8n.headers.forceSTSHeader=true
      - traefik.http.middlewares.n8n.headers.SSLHost=${DOMAIN_NAME}
      - traefik.http.middlewares.n8n.headers.STSIncludeSubdomains=true
      - traefik.http.middlewares.n8n.headers.STSPreload=true
      - traefik.http.routers.n8n.middlewares=n8n@docker
    environment:
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
      - N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
      - N8N_PORT=5678
      - N8N_PROTOCOL=https
      - N8N_RUNNERS_ENABLED=true
      - NODE_ENV=production
      - WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
      - GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
      - TZ=${GENERIC_TIMEZONE}
    volumes:
      - n8n_data:/home/node/.n8n
      - ./local-files:/files
    networks:
      ipvlannetwork:
        ipv4_address: 192.168.1.76
volumes:
  n8n_data:
  traefik_data:
networks:
  ipvlannetwork:
    external: true
The containers start without any errors, and they both get their assigned IP addresses.
However:
  • When I try to reach n8n via Cloudflare Tunnel, I get a “Bad Gateway” error.
  • When I try to access it directly (e.g., https://192.168.1.76:5678), I get “ERR_CONNECTION_REFUSED.”
I can ping the container IP (192.168.1.76) successfully, so networking seems fine.
I suspect this might be related to how IPvlan isolates containers from the host network, but I’m not sure how to properly make it reachable.
Can anyone help me figure out the right configuration to make n8n accessible when using IPvlan?
hello @Ysfyuksel
You didn’t specify the ports setting for the containers, so nothing gets exposed by Docker.
Publishing and exposing ports | Docker Docs
Thank you! It worked after I specified the ports.
I thought it wouldn’t be necessary to define them since the container already had its own IP address.
