N8N not refreshing Oauth token in graphql node
I am using the Pipefy API with a service account, which is an Oauth2 authentication . This authentication works until the token expires. When the token expires using the graphql node it does not update the token:
The API correctly returns the code 401 when an expired token is sent, the same query (with the same expired token) in the postman
  • n8nVersion: 1.58.2
  • nodeJsVersion: 20.15.0
  • database: postgres
  • executionMode: regular
  • license: community
Adding one more information…
In the normal HTTP node, authentication works and the token is renewed, this behavior only happens in the graphql node.
Hi @Luan,
This sounds like a bug in the GraphQL node, thanks for bringing this to our attention. Will investigate this internally and keep you posted :slight_smile: Tracking [NODE-1766]
Hey @aya, any updates on this issue?
I can confirm that the problem continues in version:
core
  • n8nVersion: 1.69.2
  • nodeJsVersion: 20.18.0
Hi @Luan,
No updates yet unfortunately :frowning: I’ll ping internally to see if we can bump this up. In the meantime, I recommend that you use the HTTP request node instead.
Hi @aya , still no updates? This is an important stopper for us :frowning:
Hi @pitazzo, we don’t have an ETA for this yet unfortunately :cry: You should be able to use the HTTP Request node instead in the meantime. We’ll update this as soon as we have any updates :slight_smile:
@pitazzo I followed Aya’s tip and am using normal http node, like this:
New version n8n@1.107.0 got released which includes the GitHub PR 17891.
