Hi everyone,
I’m opening this post because I’d like to understand something.
For my studies, I’d try n8n.
I have decided to deploy n8n on a VM without use docker but npm.
My VM running Debian 11 with node.js 18.16.0 and the latest version of n8n.
I have modified N8N_HOST environment variable to join n8n by IP address.
I have no problem to access to n8n via the VM web browser but if I try to join the URL via another VM in the same LAN other than the WM hosting n8n (even if evething look work normally), I can’t launch a workflow the error “Connection lost” systemically occurs.
I have tried many things but the result il always the same. Do you have an idea? Am I doing something wrong?
Information on my n8n setup:
- n8n version: 0.227.0
- Database: SQLite
- Running n8n via: npm
- Operating system: DEBIAN 11.7
