The value of config “GENERIC_TIMEZONE” would be respected by the Cron node, but not by JavaScript code
You should set both TZ and GENERIC_TIMEZONE together
Like this :
Perfect - thank you. How do you reboot docker so that it takes effect; can’t seem to see it working in n8n yet, but suspect because i need to reboot/restart docker
