Hello you n8ners,
does one of you know about SAP AppGyver Composer PRO?
I have the following problem.
Initial situation: I am trying to build an API endpoint for an MSSQL DB in Azure.
It works perfectly (see picture). I can easily access the webhook with a browser or with Postman.
The problem I also try to make this call from AppGyver and it leads to the error.
Error: TypeError: NetworkError when attempting to fetch resource.status: -1
Resource settings for Get collection (GET)
Resource URL: https://demo.app.n8n.cloud/webhook/some-uuid/
Relative path:
It is clear to me that the problem is not with n8n, but maybe someone knows the error message or had something comparable with an n8n webhook.
Thank you very much
