n8n Workflow Automation / AI Agent Creation / Multimedia Automation
Budget: Under $500
Category: n8n Workflow Automation / AI Agent Creation / Multimedia Automation
Project Type: One-time setup (with potential for future collaboration)
Timeline: Ideally within 1–2 weeks
:brain: Overview:
I’m looking for an experienced n8n expert or automation wizard to help me create a complete automated workflow that replicates the format and flow of videos from the following YouTube channels (though in different niches i will share with you later):
My goal is to automatically generate and publish hypnotic-style YouTube videos on autopilot—in multiple languages—with AI and automation tools. If you’re skilled with n8n, AI agents, automation, video/audio generation, and multi-platform publishing, this project is for you.
:bullseye: Deliverables:
A complete n8n workflow that can do the following:
:white_check_mark: 1. Script Generation
*Automatically generate scripts following a specific set of guidelines and framework
:white_check_mark: 2. Video Generation
  • Automatically generate hypnotic videos that are at least 90 minutes long
  • Include:
    • Engaging and calming storytelling (via AI or scripted prompts)
    • A hypnotic background soundtrack
    • Crackling fireplace sounds layered in
    • AI-generated or royalty-free visuals (if necessary)
:white_check_mark: 3. Multilingual Output
  • Generate the same video in 5 languages (English, spanish, french, german, portuguese)
  • Automate the translation of script and voiceover using tools like ElevenLabs, Whisper, etc.
:white_check_mark: 3. Upload to 5 YouTube Channels (1 per language)
  • Upload each language version to its own dedicated channel via YouTube API
  • Use SEO-optimized titles, descriptions, and thumbnails (can be templated)
:light_bulb: Tools & Integrations You Can Use:
I’m open to your suggestions, but here are tools you might already work with:
  • n8n (self-hosted or cloud)
  • ChatGPT / Claude / other LLMs for story generation
  • ElevenLabs / PlayHT / Whisper for voiceovers
  • FFmpeg / Descript / Runway / Pictory for audio/video editing
  • YouTube API for publishing
  • Google Translate / DeepL for translations
:white_check_mark: Requirements:
  • Must build a working, testable end-to-end system (from idea to upload)
  • Code/workflow must be modular and editable for future changes
  • Prefer no-code/low-code + AI stack (unless you’re providing instructions or modules I can maintain)
:dollar_banknote: Budget:
  • Budget: Under $500 USD
  • Can offer bonus and/or future work if this goes smoothly and happy with the outcome if automations work with no errors with the desired outcome
  • Note: I have many workflows i need built for my marketing projects and clients, so there’s tons of potential for future work as well and eventually come on board on a monthly retainer at some point just to overlook the workflows and and fix any potential issues
:envelope_with_arrow: How to Apply:
  • Please share:
    • Relevant past experience (especially n8n/AI/multimedia workflows)
    • Your proposed tools/tech stack
    • Timeline for completion
    • Anything else that shows me you can make this happen :fire:
Let’s build something magical.
Looking forward to hearing from you!
Hello @mrjay, we can schedule a call: Calendly and you can let me know if you are available for a call now so I can send a meeting link
Hey, Jay
I got you, I have been building all forms of automations for the past 2 years and have built 100s of flows for my clients. Have worked with all sorts of companies and gotten them 10s of thousands in revenue or savings by strategic flows. When you decide to work with me, not only will I build this flow out, but also give you a free consultation like I have for all my clients that led to these revenue jumps.
I have built a similar workflow like this for one of my clients. I can not only share that but also how you can streamline processes in your company for faster operations. All this with no strings attached on our first call.
Here, have a look at my website and you can book a call with me there!
Talk soon!
Hey Jay,
This looks like a fun challenge. When I build multi-language video workflows I break the journey into three stages: 1) script generation, 2) media assembly, and 3) distribution. n8n works well for this because each stage can live in its own sub-workflow and you can pass data between them with webhook calls.
Typical pattern I use:
• Trigger node pulls a topic from a spreadsheet or database and sends it to an LLM node for the first-draft script.
• Parallel branches feed the script into ElevenLabs (or similar) for voice in each language, then an Exec/FFmpeg node layers soundtrack, fireplace ambience, and AI-generated visuals.
• A SplitInBatches node loops over the five language variants and calls the YouTube API node with the correct channel credentials, title template, and thumbnail.
Tactical suggestions:
• Store interim assets in a cloud bucket (S3, GCS) and pass signed URLs rather than large files—keeps the workflow lightweight.
• Add a MediaInfo check before upload so any rendering issues are caught early instead of blocking the whole run.
• Use Error Trigger in each sub-workflow to send yourself a Slack/Discord alert when something fails so you can rerun just that segment.
A couple of quick questions to scope it properly:
  1. Do you already have ElevenLabs/Whisper API keys with enough concurrency for 90-minute audio in multiple languages?
  2. Will topics be manually provided or should the workflow research ideas automatically based on channel niche?
This is general guidance based on my experience with similar automation projects.
Hello,
I’m very interested in your project. I specialize in building end-to-end AI automation systems using n8n, Make.com, Go High Level, Syntflow, and Claude, with experience in AI content creation and multimedia workflows.
Relevant Experience:
I have built automation pipelines that combine AI script generation, voice synthesis (ElevenLabs, Whisper), multilingual translation (DeepL, Google Translate), and video rendering (FFmpeg, Pictory, Runway). I also integrate publishing systems with YouTube API for automated uploads, metadata, and scheduling.
Proposed Stack:
  • n8n for orchestration
  • Claude / ChatGPT for script generation
  • ElevenLabs + Whisper for multilingual voiceovers
  • FFmpeg + Pictory/Runway for video assembly
  • DeepL for translations
  • YouTube API for publishing and SEO automation
Timeline: I can deliver a working testable system within 10–14 days.
Budget: I can work within your $500 budget and am open to future collaboration.
This workflow will be modular, scalable, and editable so you can adapt it to new niches and channels.
Please feel free to check out my LinkedIn profile.
Best regards,
David
Here is my LinkedIn
