Native JSON output via schema in OpenAI, Gemini and Grok (links included)
Hi, OpenAI, Grok and Gemini now enable to provide JSON schema (in various formats) to obtain JSON data.
I have found few questions here in forum asking something similar but the answer was always to use “Output Parser” which often fails and requires several retries to get things right.
Is there any plan to include this possibility in the current agent? If not how could I add this without reinventing the wheel by writing a whole new community node?
Thank you.
I took a stab at creating a community node, but I’m getting errors that the node cannot be loaded:
Any idea why?
