I’m planning to start news page now I want to know abt api keys that can use for it and cost for it.
hello @mariza
Please, describe the question/issue. It’s not clear what you’re talking about.
Hi @mariza Welcome!
If your news page is going to have custom images you need to buy some credits here:
i personally use this and this is really nice! Also i am assuming that news app would display all categories of news, so consider using the inbuilt Hacker News node that brings a lot on the table with the job tag, also what i would recommend is that use n8n as a backend do not let n8n be the source of everything , create a cool frontend host it on github pages and use n8n as a backend login user details and a lot more like i made a news application using hacker news and n8n, you can see it below:
Again this is not completely n8n built but i have used a lot of logic with n8n, also consider using Openrouter for API keys for multiple different models so that you get the most out with one single wallet of credits.
Hope this helps.
An amazing idea for a project to start @mariza picking an API that allows you to fetch the information that you need for a reasonable price is quite important here.
