Hi everyone,
I’m looking for an n8n expert who understands Cliniko’s API, especially creating individual appointments using POST /individual_appointments.
My setup:
I already have patient creation working in Cliniko
n8n receives all the correct fields (start time, end time, practitioner ID, business ID, appointment type ID, patient ID)
But the appointment creation always returns “Validation Failed” with errors like:
practitioner_id doesn't exist or is inactive -
max_attendees is not a number -
starts_at can't be blank -
ends_at can't be blank
Even though I confirmed all IDs (business, practitioner, appointment types) directly from Cliniko and they are correct — so something in the body format or the structure is wrong.
I need someone to:
Review my workflow (simple, only a few nodes)
Fix the Create Appointment HTTP request
Make sure the body matches Cliniko’s exact required format
Test it so appointments actually appear inside Cliniko
Optional: help structure the workflow cleanly so I can reuse it for multiple clinics in the future
This is paid work, and I’m ready to start immediately.
Please reply with your availability and your experience with n8n + Cliniko API.
Thanks!
