Hello i am ner to n8n.i need help.
I am working on Sales mail Automation
If sheets will have thread ID then it will go to false branch , check follow up interval days and pass data llm chain to draft a follow up mail it will return ( “to”,”subject” and”body” } after that it will go to html node and create html body with thread UI for that it will take previous mail with html tag from google sheet’s data which I can’t get . From html node I can not extract the data of if branch (client CRM data).
I have tried several ways like to match client mail from google sheet and LLM Chain “to” mail to match and extract data but it is not that much feasible.
[item 0]
An expression here won’t work because it uses .item and n8n can’t figure out the matching item. The node ‘Follow up Mail LLM Chain1’ didn’t return enough information.
- n8n version: 1.74.1
- Database (default: SQLite):
- **Running n8n via (Docker, npm, n8n cloud, desktop app):**n8n
- Operating system: mac
