Need Help Integrating n8n Virtual Try-On with FlutterFlow
Hi everyone ,
I’ve successfully built a Virtual Try-On AI workflow using n8n, and it’s working perfectly when tested via direct webhook/API calls. The system takes two image inputs (person + clothing), processes them using an AI model, and returns a final try-on image URL.
Now I want to integrate this into my FlutterFlow app, but I’m a bit stuck on how to:
  1. Send the user-uploaded images to my n8n webhook from FlutterFlow
  2. Handle the response (processed image URL) and display it in the app
  3. Possibly show a loading indicator while the image is being generated
If anyone has experience with FlutterFlow + API/Webhook integration, especially sending image data and handling polling results, I’d appreciate your guidance or help setting this up.
I’m open to:
  • Step-by-step guidance
  • Sample project / tutorials
Thanks in advance!
Rakesh
CORS is the issue. Go here for the solution…
