Need help on split in batches node
I have this workflow
The “Split in Batches” node processes only the first batch of products and then stops the workflow without continuing to the next batch. I need to modify the workflow so that it processes all products in sequence and only stops once all batches have been successfully processed.
Hey @josephavetti , for the Loop node to work (iterate over items) you need to close the loop.
hi, thanks for responding, how do you close the loop? i am quite confused this work.
I showed you already in my screenshot and pointed out with the big yellow arrow.
