Guys why I don’t have function to install custom NODE in the setting, how I can do it on web version ?
moved from Help me Build my Workflow to Questions
Hi! Are you the owner of that instance? You need to be as described on our documentation: GUI installation | n8n Docs
Hope this helps!
Hi, I dont have tab community nodes in the setting ( Maybe because of trial version ?
Community Nodes are not available on Cloud if you are testing it over there: Install and manage community nodes | n8n Docs
They are only available for selfhosted version of n8n
Thank you very much
They write about this and in Youtube they show from the settings there is a function but I don’t have it that’s why I don’t understand why ) To install a community node:
- Go to Settings > Community Nodes
