Need help validating credentials in a workflow
I keep getting an invalid credential error code even tho I have created new API tokens over and over. why?
Hi, I could help you wit this can we discuss in detail?
ty for responding. I have a workflow that has a seedance node that integrates Replicate. every time the workflow gets their it gives an error that says check credentials.. I’ve checked and rechecked and even done new token API values and it still won’t work
@Jay_Bee when this happens and the credentials are confirmed, it’s usually not the API key itself, but how the credentials are being passed at runtime (node version, execution mode, or environment-level config).
This is one of those issues that looks simple but hides deeper setup problems. If you want, DM me and I can quickly audit the workflow and fix it so Replicate runs without errors
how do I dm you?
Let chat on LinkedIn are you in LinkedIn? @Jay_Bee
https://www.linkedin.com/in/michael-orion-13b473343?utm_source=share&utm_campaign=share_via&utm_content=profile&utm_medium=android_app
yes. Jay Bee
Hey @Jay_Bee !
Welcome to n8n community!
If youu used a generic Header Auth credential, make sure it looks like this:
Value: Bearer YOUR_REPLICATE_TOKEN
Can you share am image with that?
Hide /replace sensitive informations!*
Cheers!
Hey @Jay_Bee !
Thanks for sharing the images.
In the credential popup , where you have the token you must include the literal text Bearer (with a space) and then your token in the Value field.
Here is posted by one of the staff members:
Cheers!
