Need help with Error Debugging (Retry Unsuccessful)
Hi, I have a zoom meeting automation system that should trigger for all meetings whenever there is a recording available. So my workflow starts with a webhook that is triggered from zoom, it is receiving all events like whenever a recordign is availabel but it is throwing errors on some meetings data.
And when i try to see in executions it shows nothing. the workflow is triggered but i am unable to see any logs. please check the screenshots. how should i debug this issue?
It is important to know what your setup is so please answer with the information asked by the bot.
  • n8n version: 1.59.4
  • Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
  • Operating system: windows
Hi
From the screenshot we aren’t able to figure this one out! Just to confirm you’re on our cloud? Can you share the workspace name?
Do you have any details on any of those initial triggers, assuming you know which one generated which flow?
Would be also great if you could share the workflow.
Thanks!
I’m on the community edition plan. And im having this issue where my execution would fail but the error wont show up on the executions tab.
workspace name is https://n8n.lastrev.com/. i did setup an error workflow to see logs via an email. but that stil isnot enough for me to debug, i need to understand why the errors are not showing up on the executions tab. like in the screenshot attached you can see no node showing the error. and it says error loading 502.
pls check
Please note that this version is 5 months old - update to latest first to make sure this issue hasn’t been fixed in the mean time.
