So i have 2 tables - Input1 and input2 as follows –>
Input1 is feeding into a loop and creating input 2. once the input2 is completed, i wan tot join input1 and input2 whihc i trying to via merge.
The issue is that when i am joining it, 2 issues are happening –> 1. the data is not joining 2. I am not getting all the columns from both the tables
Attaching both tables and the merge output below below
input1 –>
Input2 –>
merge –>
I ahve tried everything. Even changing the table names and colukmns properly but nothing seems to work.
krisn0x
September 1, 2025, 3:20pm
2
Hey there!
Can you try renaming the columns and use this updated syntax?
SELECT
input1.column1,
input1.column2,
input2.*
FROM input1
LEFT JOIN input2
ON input1.column1 = input2.column2;
system
Closed
November 30, 2025, 3:21pm
3
