Hi there, I am new to n8n and also automation in general, so I apologize upfront if I have created a duplicate issue here.
I have output data from a node that provides the response as follows:
Name of the customer: John Doe (or just John, in some cases), Place of origin: Chennai, Age: 25.
I now need to transfer this information to the Google Sheet that I maintain. The sheet already has separate columns for ‘Name’, ‘Place’, and ‘Age’.
But, when I integrate it, the entire response is pasted in the first column like “Name of the customer: John Doe (or just John, in some cases), Place of origin: Chennai, Age: 25.”
How can I split this up into individual values and paste them into the correct columns in that row?
I did try the response provided in this thread, but I am not able to match the regex values properly.
The output returned by the last node:
Required Output:
- n8n version: 0.221.2
- Database you’re using: Postgres
- Running n8n with the execution process:own
- Running n8n via: Docker
