Nested loop not stopping
Hello, I’m having a hard time understanding how loops work in n8n.
My nested loop seems to continue even if the condition is true and add a video to the playlist.
Is there any way so that it stops before it goes through all the items, or is there an other way to achieve what I want ?
Thanks in advance for your help !
  • n8n version:: 1.45.1
  • Database (default: SQLite): : SQLite
  • Operating system: : windows
hello @Norhaa
Nested loops won’t work. Instead, use the sub workflow with the Execute Workflow Node
I modified as you said and it worked, thank you so much !
