The “Create new document1” node will not run when the workflow is executed, but clicking the play button above the node executes it just fine. When I do that, the entire workflow works as expected. Any ideas? It feels like a bug to me.
Please share the workflow
- n8n version: 0.195.5
- Database you’re using (default: SQLite): SQLite
- Running n8n with the execution process [own(default), main]:
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
