Hi everyone,
I’m encountering a peculiar issue with a loop in my Node-RED workflow and I’m hoping someone can help me troubleshoot it.
Workflow Overview:
My flow is designed to:
Download two files from an FTP server using the “FTP2” node.
Loop through each of these files using the “Loop Over Items1” node.
Inside the first loop, perform another loop (“Loop Over Items”) for further processing of each file.
Process the data and send it via a POST request using the “post_pdf2M1” node.
Finalize the flow with the “Replace Me1” node.
The Problem:
The first file downloaded from FTP is processed correctly, going through both loops and completing the flow. However, the second file only goes through the first loop (“Loop Over Items1”) and does not enter the second loop (“Loop Over Items”).
I try with different pdfs, the promblem is always and only for the second file.
Any insights or suggestions on why the second file isn’t being processed in the second loop would be greatly appreciated!
Thanks in advance for your help!
- **n8n version:**1.76.1
- **Database (default: SQLite):**default
- **Running n8n via (Docker, npm, n8n cloud, desktop app):**docker
- **Operating system:**win 11 24h2
