On this workflow I need to send 2 routes to the same output node.
It this possible? I tested on the past but i had some problems.
- n8n version: 1.51.2
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: ubuntu
n8n
2
- n8n version:
- Operating system:
Yes, perfectly possible. It’s like an IF ELSE.
(brasileiro aqui também
Thanks! Testes yesterday and its working
For some reason the last test I made was giving me bad outputs!
Sometimes refreshing the browser cache solves those occasional bugs.
Specially when testing with too much data or too many nodes.
What I like to do is pin the data on the trigger node, so I can refresh or leave the page and still keep the same data to run the tests.
