Node that reads ActiveCampaign contacts is not respecting contraints
When executing the ActiveCampaign node, I’m limiting the search of contacts by tag and limiting the output to 90, but the result is my whole ActiveCampaign audience. I already tried changing the parameters, but everytime the result is the whole audience. Is this a bug?
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
Hey @tmsiqueira,
Welcome to the community :raised_hands:
It should only return the 90 records so it does sound like a bug with the node, What version of n8n are you currently using?
Hi! It was returning over 16,000 records… But it is working now for some reason. I’ll post if the issue occurs again.
Thanks!
