One my workflow nodes the monday one gets stuck and does not stop running. I noticed that it happens when the date is 2022-11-21. I had the same problem yesterday in similar workflow. I deleted the Monday node and set it up again. That made it work. Is did not help with this one. To stop is I have to restart the complete instance.
No error message. Just keeps running.
Please share the workflow
- n8n version: Latest stable cloud…
- **Database you’re using (default: SQLite):none
- Running n8n with the execution process [own(default), main]:
- **Running n8n via [Docker, npm, n8n.cloud, desktop app]:n8n.cloud
